Discuss Tips for attaching Qualpex to GunBarrel in the Central Heating Forum area at PlumbersForums.net
Hi, I want to move two radiators and they are currently on GunBarrel pipe (i think, see attached pic "GunBarrel pic").
I understand I need to unscrew the existing pipe and screw in an adapter fitting to connect qualpex, then route this to the new rad. (see the "planned pipe" pic for what i'm planning)
Are there any tips for removing this old pipe? it looks fairly rusted, do i just hang out of it with a pipe wrench? I've sprayed a load of wd40 and will let that soak.
Any tips would be really appreciated. Thanks
Drain down
If they won’t unscrew apply some heat eg blowtorch
Will be 1/2
Perhaps 2 pairs of whatever you're using, one to turn, one to hold against. Need to open plenty of space to get tools on.
Multi tool will help you get the tongues off the t+g or circ saw - very carefulling!
Reply to Tips for attaching Qualpex to GunBarrel in the Central Heating Forum area at PlumbersForums.net
The rusty bit with a hole at the top looks quite old, feels flimsy, and is a single skin 100mm x 400mm. The boiler has a 600mm new pipe rising...
Attached is a ground floor picture of the soil pipe in our home. There was originally a toilet which has now been permanently capped off and you...
1K
  • Solved
Hi There, I want to swap out my old valves for TRVs but the threads are different sizes, and I'm unsure how to resolve it. My current existing...
2K
Daley power
Hi I have a leak from one of the pipes, going into the hot water cylinder, in the airing cupboard. There are 2 pipes going into the cylinder on...
9K
Hello everyone! I'm finally getting to do my own bathroom renovation (spend most of my time doing everyone else's). The bathroom is on the ground...
4K
