Discuss Toilet Cistern Overflowing (Picture Included) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
You tube get me so much work.Not a difficult DIY job, do not use cheap parts, Youtube is your friend.
Neither fit a new one.
Making sure you fit a part 2 or 3 and an isolation valve in the pipe feeding it. If you get like for like you need a double check valve also.
Look it up on Wras websiteSorry what do you mean by part 2 or 3? Im guessing the check valve requirement is due to the lack of air gap?
Sorry, the float valve you have is part 1 (old type) part 2 is brass and part 3 is plastic both with air gapsSorry what do you mean by part 2 or 3?
- correct but not needed if you install a part 2 or 3, an isolation valve is a requirement of water regs regardless, unless you opt for the repair option as suggested by some members.Im guessing the check valve requirement is due to the lack of air gap?
Reply to Toilet Cistern Overflowing (Picture Included) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
