Discuss Toilet seat query. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
katatutu
Got a call from a tennant saying that the toilet seat has come off. They have sent the following pictures. Does this look like a job a non plumber could do - or is best to call in someone. I am clearly not a plumber. Would the toilet need to come out to get underneath the holes? It is in a block of flats.
http://i262.photobucket.com/albums/ii119/kata_tutu/Plumbing/IMGP1516.jpg
http://i262.photobucket.com/albums/ii119/kata_tutu/Plumbing/IMGP1515.jpg
well your not touching water so a standard DIYer should be okay
taking the fixings of and take it all down to your local merchant or B and Q and get a new seat
Does it look like the toilet needs to come out to get under the holes though?
looks like a normal close coupled set to me should be able to get at the bottom of the seat fixings.
Love the jimjams and tiny feet!!
Mucky job but DIY. You'd probably have to phone 3-4 plumbers before one would say he'd do the job. It's not the difficulty, just the lack of reasonable profit to be made as most people would query a £50 call out (plus £20 plus for the seat). If it goes quickly it should only take 10-15 minutes. Little tip ... before you install new seat, give the pan a really good clean around the hinges as it makes all the difference when fixed.
If you cant get underneath just get a BLIND HOLE FIXING SET (PAIR) FOR TOP FIX £5.94 from Plumb Center part E40597.
Reply to Toilet seat query. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
