Toilet waste pipe re location if poss
View the thread, titled "Toilet waste pipe re location if poss" which is posted in Boiler Advice Forum on UK Plumbers Forums.
scott2017
Hi i would like to move my toilet in my bathroom so i can change the layout to get more space the waste pipe is not in the corner off the room like normal can extend the waste pipe and put a 90 bend on it i posted a drawing of where i would like it to go
The green arrow would be the new waste pipe run
any help would be very greatful
thanks
Looks ok as long as you have the correct fall on the waste pipe, your moving it to aprox centred of the long wall
Internal or external stack pipe ?
hi matey ya the toilet is goin in the centre of the new wall and the stack internal there is a pipe in the corner which is where my bath water gos down but the toilet down down a different stack which i have not seen before matey
cheers shaun for replying on my post matey
Yes other than the need to alter the stack should be a simple job
TBH unless you have a decent hands on knowledge in doing stacks best get a plumber to do it
But it's doable
there is a downstairs but its on the same as the upstairs toilet could i put the new toilet waste pipe into the stack where the bath feeds too
Reply to the thread, titled "Toilet waste pipe re location if poss" which is posted in Boiler Advice Forum on Plumbers Forums.
scott2017,
scott2017,
