Discuss Toilet waste section identification in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
Nolski
Hi I am in process of planning a remodelling of ground floor cloakroom in a 2007 build house. I may want to move my WC from one end to the other which is distance of about 7 feet and will require slightly longer soil pipe section being run and boxed in. However I have found that this toilet waste pipe bends directly out of P trap a few inches into a T stack which is boxed in, this is not however the main vent as it's only about 18 inches high before terminating. I have a second bathroom on first floor which has same design and was wondering if this had a specific purpose as nothing else branches into this and I see no reason for it. Neither have AAV fitted, both are only about 18 inches in height. Do these have a function? If so what and can I move it? Any insight appreciated.
Reply to Toilet waste section identification in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled...
I currently have a floor standing pan in a downstairs cloakroom. The waste is vertical about 10mm on the inside of a 2- brick external wall. As...
2K
I’d like to replace the toilet in my house with a back to wall one. The plan is to build a panel on stud work to conceal the cistern and then use...
2K
J
Renovating an upstairs bathroom. Void between floor boards and ceiling below is too narrow to hide the waste pipe from a wall hanging toilet. My...
2K
L
Hi all, First post here so please be patient. We recently had our ensuite remodelled and were initially really happy with the result. However...
