Currently reading:
Top 10 tools you always use
Discuss Top 10 tools you always use in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
freakmaster
Hi, I would like to know what are the top 10 stuff or tools you like to have always on hand.
Are there screws, duct tabe or screwdrivers, you always use. I excluded the Plumber wrench:smile5:, because i think most of you already have 3 arm just for it.
Let me know, I looking for an inspiration to make your work easier
[h=1][/h]
I don't want to put a downer on it mate, but I wouldn't have thought there is any need for an arm tool holder in our trade. We need to get our arms ( and bodies ) into small spaces, a watch is sometimes a hindrance!!!
Tool vest is useful, can be removed quickly and easily if needs be.
ok thank you all for your input, I will see what the other craftmen areas will say
Good one Croppie , otherwise its put down tool bag/sack , and climb inside oversize cupboard under sink , catching self on alloy bands attached to earth bonding cables !
Bahco 8" wide jaw adjustable
Rothernberger 10" grips
Tape measure
Pencil
No. 2 Pozi Screwdriver
Spirit Level
Stanley knife
Pipe slices
Torch
Hammer
Used most of bellow on dailly basis:
4mm Wera screwdriver
No. 2 Phillips Wera
No. 2 Pozi Wera
8mm Wera slotted driver
Bahco 9033 Wide adjustable
Bahco 8070 small adjustable
Knipex KN 86 03 250 Pliers wrench 250 mm
Rothenberger 7-inch Water Pump Plier
Regin premier 45 manometer
Fluke 116
Pen
Get a long 17mm open ended spanner, it will fit most valve pegs.
Bacho wide 8" adjustable spanner
Rigid 12" pipe wrench
Knipex 250mm cobra pliers
pipe slices
Wera chisel screwdriver set
Magnetic spirit level
Stanley fat max tape measure
Estwing hammer
Lenser head torch
Allen key set
Reply to Top 10 tools you always use in the Plumbing Jobs | The Job-board area at PlumbersForums.net
