Discuss Totally Confused - Sink plumbing fixtures in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone,
I have been having quite a lot of blockage issues with the sink waste pipe and so decided to take the waste pipe to the drain outside. So i got my DIY hat on and purchased a core drill to make the whole in the wall to feed the waste pipe out. It was a learning curve but finally managed to get it done.
Then I had to figure out how to add to the sink/waste pipe in order to add an additional pipe to feed the waste pipe outside. The setup at the moment is this;
Two sinks => connects to U-Bend => connects to waste pipe which goes around the kitchen and out of the main waste pipe.
I wanted the existing waste pipe to still have a connection as the washing machine and dish washer is connected to it and thought if it ever gets block on the normal one, it can still come out from the "new" waste pipe.
OK cut the story short, I am totally confused on which connection to use. I bought the Push Fit Tee but it doesnt seem to connect to the existing pipes. Can someone please help me to understand this and advise what I will need. I understand for the pipes that lead outside as its simple, but its more about the bendy stuff that has me confused. I have attached some photos. I should have taken a photo when the U-Bend was attached and then the other pipe that leads to the waste pipe but i forgot. I will taken individual photos of them. I confused on which fitting to use where.
Sorry to say it mate but that looks a right dogs dinner. Your water trap is surely going to be below your hole out the wall??? Maybe itā€™s the angle of the pic?
i would say the bend attaches to the t piece then the 90Ā° attaches to the bend to take you to the wall pipe. I donā€™t see how youā€™re going to stop smells coming up the old pipe though
lol yeah it is a bit of a dogs dinner. i was thinking of doing the trap outside?
my problem is on finding which fittings goes where, i was wondering if there is some information on the different fittings/fixtures and how they connect to each other.
Also, i would really appreciate it if someone can tell me what is the name of the Tee in the photo. I dont think it is a Push Fit because the one i bought is different (at least the bottom connector in the photo).
Tee is a compression tee but I think itā€™s part of a waste trap. Donā€™t do trap outside itā€™s standing water and will freeze. Iā€™ve said how the bits go together
Reply to Totally Confused - Sink plumbing fixtures in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
