Discuss Towel radiator not heating in the DIY Plumbing Forum area at PlumbersForums.net
Hi all,just an update from yesterdays post,the towel radiator has miraculously fixed itself!it is now red hot,I still don't understand how after bleeding full system including new rad,it should suddenly fix itself,May be some of you clever people out there could explain, cheers
Air lock is the most probable cause
Reply to Towel radiator not heating in the DIY Plumbing Forum area at PlumbersForums.net
Sonya K
