Discuss Towel Rail Valve Advice please (35 Characters needed.) in the UK Plumbers Forums area at PlumbersForums.net
I have had a look at previous posts and think I know the answer to this but just before I make it worse could I just check what you think about this one.
Granddaughter just moved house and this valve decided to leak when it was closed.
When open its fine.
Normally I have repacked the gland on radiators valves but I read that Towel Rail valves may not be able to be repacked?
My first problem is how to remove the cap (Towel Rail valves in our own house have a screw to hold cap in place) - Is this one just a push fit and needing a bit of persuasion to get the cap off, so I can see if the valve is re-packable?
The cap is fairly thin metal, that has been painted in the past.
Thank You.
The end of the end cap should unscrew
But normally there not re packable so new valves required
Thanks for that info. Shaun - went to take a look today and the cap is actually all one piece - no end piece to unscrew.
Had a gentle tap at the cap (from the open end) with a piece of wood and hammer to try and get some movement but unfortunately no joy.
Would you have any other suggestions please?
Change the valve
Thanks Shaun - selected new radiator from screwfix, not really needed but existing rad. is old.
Valves are straight - but even those with highest reviews get some 1,2,3 star - As a professional do you have a 'go-to' preference for reliability?
Screwfix 104FW
Reply to Towel Rail Valve Advice please (35 Characters needed.) in the UK Plumbers Forums area at PlumbersForums.net
