Discuss tricky soil pipe connection in the USA area at PlumbersForums.net
Hi
I need to connect a kitchen sink to a soil stack but the soil stack has an inspection hatch and what looks like a reducer into a clay pipe into the floor making it very difficult to fit a boss.
This should be pretty straightforward with a boss, but the level where the boss needs to fit is not a clean pipe area it has an inspection hatch and what looks like a reducer into a clay pipe. The pipe is at the back of the kitchen which I needed to pull out to take the photo which is attached. The copper pipe is a gas pipe to the kitchen cooker which complicates the area to work in.
There is a section of soil pipe that a boss will fit closer to the top of the worksurface but that doesn't help the fall of the pipe from the Belfast sink.
The current waste from a belfast sink is coupled with a washing machine and dishwasher outlet which has been directed into an outside trench drain channel outside which collects rainwater and clearly messy for any food debris coming out of the sink being flushed into a freshwater drain.
The house is a cottage extended with block/ brickwork but the property has previously had a long history of changes.
Any possible options?
diy_m
Remove the access section
Re do the clay connection to soil
tee with an boss on the side then install an access fitting in the tee
you might need a slip coupling for the above
I do hope that the dishwasher/washing machine do not discharge into a surface water drain, if so that’s a big no-no as it’s classed as foul water.
Thats great feedback ShaunCorbs,
After doing some fitting reading I see what you mean, access pipe with a socket for the waste that would look good and yes I would need the slip coupling to put it all back together.
I am unsure what to use for the soil pipe connector type that would interface to the clay pipe size, it looks like a reducer on there at the moment ( slightly smaller clay pipe ), what would you recommend?
Many thanks!!
diy_m
Hi Aquarius,
You are so right but unfortunately, it is, all discharge, sink, washing machine and dishwasher, go to clear water drain, pretty disgusting especially as the freshwater drain is leaking/leaching into the ground ( for another post tomorrow ) and saturating the outside wall and smelling badly.
I am here to right the wrongs after getting into a new house with a number of faults, hopefully all sorted out soon.
Kind Regards
diy_m
It could be they’ve just put the pipe in and cemented around eg in the collar you could do the same or you could grind the collar off and use this McAlpine DC1-BL Drain Connector Black 110mm - https://www.NoLinkingToThis/p/mcalpine-dc1-bl-drain-connector-black-110mm/4255v
Sorry for the delay in replying
That looks like a good route so have bought the McAlpine fitting in preparation but will also have some cement and angle grinder on standby if I need to do the other.
Many thanks for your help!!
Best
diy_m
Reply to tricky soil pipe connection in the USA area at PlumbersForums.net
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the...
Sonya K
