- Messages
- 2
Hi new member and first post. I've just installed a Triton Home digital shower (low pressure version twin outlet). Having ran the commissioning mode for several minutes I then turned the shower on but am getting hardly any water coming out the shower heads. Flow rate into the pump is c 6ltrs / min. I've had several conversations with Triton installer and he has said there is an air lock. Having tried everything he has suggested - put hose on the shower tray, blow up shower hose, blow into the inlets, turn on cold water then increase the temp and back again nothing seems to work. Is there anything else anyone can advise to try here ? Thanks in advance for any suggestions.
