Discuss Tundish on unvented cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I always find this happens, my one at home only goes about 5 metres in 22mm and is 500mm from the tundish to the first bend. You have to let the pressure go slowly or the water goes everywhere.
Ok if the pressure or temperature relief did blow of is it likely to be at full bore or not? The splashing could cause some damage especially with the position of the cylinder in the loft.
As said nearly all of them do it, so what would they say?
500mm of 28mm straight from tundish does take it away quick enough though but still get the odd drip sneak out.
It a 22mm connection on the tundish outlet. And 22mm pipe takes it away 0.7 meters to first bend under tundish and less than 9 meters of 22mm pipe. Its splashing out of the tundish not backing up.
Reply to Tundish on unvented cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
