- Messages
- 2,718
The box which houses the electric connections on the pump itself, are they IP rated to resist water splashes?
Discuss Twin Impeller Pumps & IP Rating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
As a general rule are they? I'd have thought so :/ I'll Google it but just though I'd ask if they were or not.Should be on the motor label IP67 is splashproof, IP68 is rated as continuous submersion.
Cheers rpm, will keep that in mindGuess you`ll have to google the pump you fitted as would expect it to vary from one manufacture to another. WD40, wet vac and hairdryer usually dries the electrics out if need be.
Where did you get that from? IP67 is low level immersion
Another thing about this didn't make sense. The pump has isolators on each flexi on the inlet and outlets. Just out of curiosity I turned them all off and still got water flowing freely from the tap/shower. I would have thought if I isolated either the inlet or the outlet I wouldn't get anything from the tap?
Exactly. The pipework from the pump to the bath can't be more than 2m, I ran the tap for about 15 seconds without a drop in flow.If all 4 isolators were turned off then the only water left would be in the pipe from the iso to the tap/shower so doesn`t make sense to me either.
Yup, does indeedSo you're saying on all four flexible hoses it has isolators?
Makes no sense.
It's just dawned on me :/ I didn't check but the property has 2 showers on the same floor. The pump is in one bathroom under the basin which I assumed would feed the shower in the bathroom that it's in. Maybe it was feeding the shower in the 2nd bathroom... Dammit!!
Reply to Twin Impeller Pumps & IP Rating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
