Discuss two semi rigid steel connectors on gas meter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
Tod
Hi Guys,
Quick question, how would you treat two semi rigid steel connectors on gas meter.
All appliances are operating properly and all tightness tests etc have passed.
There are also no signs of corrosion on the pipework....
thanks
Yes exactly, what i wnated to know is can the LL leave it or would you need to do something about it?
ie: Ncs or AR... as it is definatley not allowed
BS6400 2006,
8.9.2 says "only 1 pliable (semi rigid) connection shall be used" on a meter installation
its not allowed but its also not AR or ID, so it'll be ncs
dont we just inform the transporter that there is a property with 2 semi rigids and they then send out and change them over.
is'nt there a technical Bulletin about this?
The transporter won't do anything as there will always be one flexi to a meter on the inlet - everything after the inlet is down to the home owner so its just NCS
Technical bulletin 084 ---- NCS---and the customer to contact the supplier to get it sorted, we're all correct.
I'm somewhat baffled why they would say contact the supplier. The meter standard shows the flexi on the inlet and rigid on the outlet, so if you have two flexis surely the outlet is wrong and it's the home owner/landlord who would correct.
Reply to two semi rigid steel connectors on gas meter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a...
hi i am currently moving home and i have been told by a plumber that the enc pipework into/out of this gas box would not pass a gas safety test. I...
Hi all, I currently have an external water meter (which is a sub-meter) of my neighbours meter. The mains supply runs into their garden and then...
Hello, I live in a two floor semi with a gravity fed conventional gas fired boiler (Potterton Kingfisher MF). The boiler is fed cold water from...
Hi just been to check a family members boiler and I’m getting just over 25mbar working pressure at the meter and 22mbar inlet pressure at the...
1K
