Discuss UFH Noises in the Water Underfloor Heating Advice area at PlumbersForums.net
I have some strange noises coming from the system, the majority are caused by the flow meters, the clicking noise. But there are other noises, ive managed to capture these on a video, keen to see what everyone thinks..
Reply to UFH Noises in the Water Underfloor Heating Advice area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
