Discuss Undersink water heaters in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Riley
Super Moderator
S. Mod
Subscribed
hi guys
i basically have no experience of fitting these so could do with some guidance. Haven't touched them since college!!!
cust has small studio flat with no gas and doesn't want to take up space with a cylinder.
My question is really two fold:
Studio has a kitchen sink and a bathroom basin. Can I get away with one under sink heater? Outlets are approx 7m apart mains enters property by bathroom basin.
Regardless of of whether I need 1 or 2 under sink units can someone recommend one? Preferably one with everything I need included.
Cheers folks
matt
Ariston 3kw 15litre. buy the expn vessel and prv as well or you'll need a drippy tap as I call them
Those there "drippy taps" are mighty expensive too!! And no matter how many times you tell people they always over tighten them!
OK with 3Kw, 15 Litres for two outlets but you can't use the vent taps (drippy taps) lame !! So it will have to be the un-vented kit Riley.
You could also try the Heatrea Hotflo.
funny, but when i did my ariston one it was a choice of drippy tap or the expn kit in the catalogue, prehaps its all changed
Redring ew15. No need for a drippy tap.
Thanks Croppie, read up the tech spec on these is the 4.5m expansion on the cold main in any direction or just as long as it's 4.5m before the heater?
4.5m before the heater but you can get a pressure reducing set including a 1ltr expansion vessel.
Nothing changed lame, if you have one heater & one appliance then yes indeed you can have a vent tap (your drippy tap) but it won't work with two appliances on one heater I am afraid, no matter how you try to configure the pipework.
I like the Hyco ones. Never bother with the drippy tap, always use the expansion vessel.
Reply to Undersink water heaters in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all! I'm in the process of fitting a replacement undersink water heater in my shed and, as advised in the instructions (yes, I know, what am I...
Hello, I have a tank Bradford White 50 gallon gas hot water heater for a 1700 sq ft home with 2 1/2 baths, HOWEVER, I am only one person living...
Hi, I have an unvented water heater which for some reason every year causes me issues. At the end of 2023 I noticed that the pressure valve...
hi all, i need help to fix the leak from a pipe connected to the water pump via flexi pipe and it is feed from the immersion heater. I have...
