Discuss unpressurized open/direct UFH with buffer tank heat source in the Water Underfloor Heating Advice area at PlumbersForums.net
The following is a proposed very simple installation of UFH open/direct to an existing 1000 gallon fossil fuel hot water storage tank:
We are told that this won't work since the UFH pipework and pump are above the height of the tank, and therefore gravity will empty the UFH... But our reasoning was that siphon action would prevent this from occurring (since both feed and return will always be below the min level of tank). We have been advised to install a heat exchanger in the tank, and make the UFH circuit pressurized, but this seems unnecessary (and expensive for us). Does anyone have any thoughts, please?
Can’t use ufh on solid fuel
May I ask why / what’s your plan ?
it's just a little off-gird cabin, in the woods, in Alaska. So no rules and regs to follow...but obviously has to work. The HW storage tank is existing, and for the upper floor / mezzanine would be nice to take advantage of that HW with UFH. Thanks
How big is the cabin ?
A good log burner should heat that space no problem
I think that the system might work okay to start with but would gradually deteriorate in performance until it reaches equilibrium with the pump and UFH air-locked and the levels in the risers matching the level in the tank. That's assuming you were able to get the pump primed and operating in the first place.
An okay solution but you'd need an expansion tank, fill loop, air vent valve (auto or manual) and pressure gauge to complete the setup.
For a cabin in the woods in Alaska, I'd have thought that you'd want a system that was as standard and reliable as possible and to keep a set of key spares on site. I believe it gets pretty cold there in winter.
Reply to unpressurized open/direct UFH with buffer tank heat source in the Water Underfloor Heating Advice area at PlumbersForums.net
Hi all, Looking for some advice. Recently moved into a new house and we've been doing bit and pieces to it, we're now at the point where we're...
Hi folks, I’m in need of some sound advice. We have recently had a ground floor extension and have had underfloor heating (company: JK UFH)...
4K
Good day all, I would like to get some advise and perhaps the solution to the issues with my UFH system. We did install UFH in an entire house...
5K
Hello all, I should start off by stating that I'm not in the industry - I'm just a DIYer with a "what-if" idea. Hybrid systems and solar...
This maybe isn't so much about asking for advice as giving it 🤔 I had a leaking HW cylinder (23 years old) that I got fed up patching up with...
2K
