Discuss Unsure on how to fit the TRV to 15mm copper pipes in the DIY Plumbing Forum area at PlumbersForums.net
I need some advice. I am trying to replace the manual radiator valves on a towelrail with a TRV:
I ordered a Myson 2TRV15SN, and the tail seems to be identical with the current setup, however I am not sure who to attach the copper pipe at the bottom. This doesn't seem like a standard compression fitting.
How do I fit this?
You would have to remove the old nut and olive and install the new ones
Yes it is a fitting for a nut and olive just reversed eg threads on the nut
Reply to Unsure on how to fit the TRV to 15mm copper pipes in the DIY Plumbing Forum area at PlumbersForums.net
