Discuss Unused UFH port........... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
plumbbobshan
Afternoon Lads and Lasses. I am setting up a 2 circuit UFH system the manifold has 3 ports. Do I blank off the spare ports or do I fit a loop and leave it turned off ? The other ports will be controlled with room stats.
Blank off or run something else off it eg summer towel rads
Reply to Unused UFH port........... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
HI folks, is it possible/feasible/reasonable to insatll an ufh manifold and system (for a 17m2 room) from a disused CH 15mm flow and return? I...
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the...
As part of deep house renovation, planning to install wet ufh on the ground floor, and radiators on upper floor. Two bathrooms will have both...
Good morning, wondered if anyone can advise please on a resolution? My set up at home is that I have a 4-bed detached with 21 radiators...
5K
Do people with this type of mixed flow temperature control have any problems with achieving the required manifold flow temperature? The one below...
