Discuss Unvented Cyclinders in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
franky
Alright guys just a question for you on the coils on the cylinders. The recovery on these can be as little as 7mins but at a massive 20kw how do you allow for it when sizing a boiler. I'm talking to my old boss about it at the mo as he seem to be putting in bigger boilers to factor in this, but I was thinking that it would be a waste to go down this route? I'm not sure what the best way is but wondered what you guys did?
if the demand for hot water is very high then it would be best to increase the size of the cylinder to cope with demand, there no need for such a high recovery rate if cylinder is sized to suite.
Which cylinder manufacturer is quoting 7 min recovery rates?
Kev
When using the 'Whole house' method to size a boiler you would allow 2kw for the hot water. As has been mentioned if you size the cylinder correctly you won't have any issues. Jonathan, That Extra Mile Heating and Plumbing, London
Use a divertor valve if it turns you on. Full power to the cylinder for X minutes to top it back up.
Same principle as a combi. Nobody notices the heat off for a few minutes.
oso doing 7min recovery if you use 26 kw to heat the coil. Thats what they say I don't think I believe it. Thought I'd ask because I have been leaving 6kw on the boiler for hot water, but went with my old boss for a few days and noticed he was using masssive boilers so he could get the recovery time, (even though the cyclinders were correctly sized for the property) like putting in 37kw boilers for a 3 bed semi two bathrooms , he's a very good plumber and has a right statto working for him.
Bit unnecessary to overdo, it its been working fine for me so far
Sounds well over the top,
normally you allow a provisonal or the rule of thumb is 1kw for every 50 litres of stored water you have
the coil rating doesn't mean you allow an extra 26kw of boiler for the coil !!
as tamz said though if you did use a diverter you wouldn't need to allow for it but i do not see that as neccisary specially if it was a larger house with more than one heating zone or one bigger zone where you require 28mm for the first section of pipe work as a diverter may restrict the flow of this down a lot more than a 2 port valve.
not only using a massive boiler is more expensive to buy it will never be at full rate and not as efficient, yes i know they do modulate down to nearly nothing but that's not the point. hope this helps atall.
That's not a good plumber that's just silly
Where is the energy efficiency there 37kw boiler in 3 bed house lol
Why not fit a matched boiler and store like the Vaillant? The ebus system turns the boiler on to 85C to reheat the hot water when required (hence higher transfer rate across the heat exchanger) and then adjusts back down to the central heating setting once demand for DHW is satisfied. That way you seem to get the best of both worlds.
Grahamep have you installed the 937 is it any good compared to an unvented set up? Have one to put in next month.
Why is the coil rating there at all? I never even looked at it until my old boss pointed it out.
Also I will stand by that he's a good plumber he's just got this wrong
Reply to Unvented Cyclinders in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm looking to purchase a 300L unvented indirect cylinder to work with a standard heat only boiler. I may have solar panels in the future...
Hi, I was hoping to replace an old system boiler with a Vaillant Ecotec Exclusive 627 system boiler, thats the one with the diverter valve so no...
I have a house with 14kw heat loss using the whole house method, ( Navien oil system boiler ) I aimed to use heat engineer software on acceptance...
We need an urgent advice, we have a gravity water system and we are in a middle of loft conversion. We are adding an en-suit in loft and prefer to...
1K
I have come to my decision I might as well do my G3, even if only for maintenance jobs. Question I have is WHY we are fitting so many of these...
2K
