Discuss Unvented hotwater cylinder in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
You either need to be a member of a competent persons scheme or get someone who is and is happy to sign off someone else's work.
It is a complete farce to be honest.
I believe building control do sign it off for a fee as they have to come out and inspect it etc
Fees around £350 I think
Is there a sign off cert that is used and anyone point me in the direction of how to get one
Need to phone up local building control and say you’ve installed a unvented cylinder and you need it signing off
Reply to Unvented hotwater cylinder in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all, new to this forum and looking for a bit of advice please. Have been noticing recently some odd behaviour with our hot water system. If...
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
Do most composite valves now for unvented cylinders have a tee on them For the expansion valve connection? The ones I used to fit just had the...
A
Hi, I'm looking to install an unvented cylinder in my property. I initially hired a plumber who expressed interest in the job, but later...
2K
My heating system comprises an Ideal Logic 12 boiler located downstairs and a Gledhill OV SOL cylinder located upstairs . The problem is that when...
