Discuss Urgent boiler malfunction and Flue inquiry!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Z
zctpfe2
Hi all,
I'm seeking for help with some multiple faults with my boiler and central heating.
I got a Baxi 2 Megaflo 28 Compact GA boiler and it suddenly stopped supplying hot water about two days ago (no big issues before except re-pressuring). I tried to reboot it however it lost power completely when I turned it off. The Honeywell central panel is functioning properly.
I called in a British Gas folk to assess the situation and he commented the following:
1. It may be the problem with PCB so it cannot be switched on
2. Our vertical flue has no support so need to get it done before any work
3. There is a minor leakage in the pipe beside water cylinder
The boiler is 4 years old and we moved in 4 months ago.
So my question is whether I should call original installer to see if they can get all fixed or I have to seek Baxi for the boiler and another plumber to deal with point 2&3.
The flue is quite firm and I wonder if there is an actual need for brackets, also will this be potential problem that my boiler is not working???
I've attached some pics here
Many thanks!!!
The flue needs brackets. Without them its classed as "AT RISK " and must be turned off untill rectified. That is the regulations
not strictly true phil it can only be turned off with the owners permission .Label issue, notice and then up to the customer if they use it
Call Baxi to rectify number 1.
And a plumber of your choice for 2 & 3.
Thanks all. I'll make a call to the original installer and see if they can get the boiler fixed as well. If not, I'll go for Baxi.
Called up Baxi and they said they have no engineers that cover my area..
Hi folks finally got it sorted. The PCB was burnt so I got a plumber to replace the PBC which is way cheaper than calling the BG... Thanks for the attentions!
Reply to Urgent boiler malfunction and Flue inquiry!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All Bit of an urgent one being that time of year and can't get a plumber out until after xmas even on an emergency callout I have just...
Hi Guys, My chimney failed the test so I need to install a flue liner for my Gazco Stockton gas fire. It was over a year ago when the engineer...
Hello everyone, I'm facing an issue with my Vaillant EcoTec 832 boiler and would greatly appreciate your expert advice. The Problem: Heating...
I currently have a Vaillant ecoTEC Plus 438 system boiler which is 13 years old. I have been having problems with the boiler which potentially...
Hi, I need to drain my vokera 29 boiler in the attic as Im going away for 4 weeks at least to make sure there are no frozen pipes. In my small...
