Discuss using a pump with a combi boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hello, was chatting to a friend, he has a good size 5 bedroom house .. current system is a combi boiler and he is looking to upgrade bathrooms and water supply as currently using a tap stop the hot water to the shower
i was surprised when he mentioned to me the the plumber is recommending keeping the combi boiler (4 years old) and adding a stuart turner booster to get the required pressure for the water stores in a 300l Main Cylinder (with pressure inlet kit and expansion vessel) up the the bathrooms on the 2 upper floors ..
i was told pressure was 4 bar
would you only keep a combi boiler if putting a new pipe from the mains proves to be tricky ? house is 1930s with i assume original pipe from mains
i assume a pressurised system including new boiler only works with a pressure that the original pipe cant supply and the pump is the only option
thanks for your advice
Thread closed
Reply to using a pump with a combi boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
