Using insert twice. In same fitting
View the thread, titled "Using insert twice. In same fitting" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I recently removed a plastic fitting with the small plastic tool for this method however the insert was still lodged in the plastic elbow. I moved the pipe a little(without cutting anything), and used the same plastic elbow into the same insert/pipe.
Will this be OK?
Reply to the thread, titled "Using insert twice. In same fitting" which is posted in UK Plumbers Forums on Plumbers Forums.
soccercelt,
ShaunCorbs,
