Discuss Vaillant 837 egg timer? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
novicegas
Hi guys, anyone know what the egg timer flashing on the new 837 is. In the status menu it says Pump Wake? Any ideas. cheers
Doesn't have a frost mode does it? Pump circulates water around the system to help prevent freezing and below a set temp brings the boiler on.
Or possibly it's acting as a shunt pump prewarming the boiler using ambiently warmed water to prevent thermal shock.
Thinking commercially anyway! Have you rung vaillant?
Has the power been switched off and on again? Not looked at instruction manual but may just been a pump purge mode, which should pass.
Hello, wondering if anyone could help. My boiler seem to be working but the radiators aren't getting hot enough. I have them in the highest but there jut not getting hot. It's been over 24 hours and still nothing.
I have a Valliant Eco tech pro 24 and the egg timer is flashing?
Hi Franki, have a look at Croppies post above. If you're still stuck you'll be better off starting a new thread.
As above.
Please register with us and start a new thread to receive additional answers to your question.
Reply to Vaillant 837 egg timer? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know a good, not super expensive, leak detection company in the London area?
