Vaillant ecoTEC Pro 28 changing AAV
View the thread, titled "Vaillant ecoTEC Pro 28 changing AAV" which is posted in UK Plumbers Forums on UK Plumbers Forums.
My AAV is leaking, it is the type with an o ring around the body that is fixed in to the pump with the u shaped pin. I know that other types have a shut of valve allowing the part to be changed without draining the system, I'm thinking mine will need draining to change it? Could anyone advise please?
Thanks for the advice. I didn't want to drain the system as I've only just refilled with new inhibitor. Reason I found out AAV is leaking was I was just inspecting internally as diverter valve is stuck as upstairs rads are getting warm when running hot water. I know for my boiler that the original brass diverter valve can be replaced with a plastic body unit which is around half the price of the brass unit, would it be a false economy to have a plastic unit fitted. Boiler is approx 6 years old so I'm expecting it to last at least another 6. Work will be done by Gas Safe fitter, but I will get the parts and drain it down as it will be done on mates rates.
Reply to the thread, titled "Vaillant ecoTEC Pro 28 changing AAV" which is posted in UK Plumbers Forums on Plumbers Forums.
Steve66,
king of pipes,
