Plumb Logic Ltd
Are any other Gas/Heating engineers having problems with blocked primary heat exchangers on Vaillant boilers, even on new installations that have been chemically flushed and have filters/dirt seperators protecting the new boiler/s ?
We are prodominantly a mechanical installation company specializing in large domestic new builds that require light commercial plumbing and heating installations.
The specifications for these developments regularly require us to install pairs of Vaillant Ecotec 46 or 65 commercial boilers or Vaillant Ecotec 637 domestic system boilers as part of a sealed, pressurised system.
The boilers are installed in a designated plant room where we also install a bespoke low loss header allowing us to seperate each heating cicuit (UFH, Radiators, Towel Rails, HW)
As each heating circuit is installed, we carry out a full chemical power flush on that individual circuit, so we know that the system is being flushed thouroughly. The newly installed radiators and towel rails are included in this flush.
We install a magnetic filtration device on each return pipe between the boilers and low loss header.
The system is then correctly dosed with the required Sentinel products before the boilers are switched on and the system is tested and commissioned.
So...In a new build development, with a brand new central heating system that has been flushed to remove installation deposits, fluxes etc. and magnetic filtration devices installed protecting the boilers...we are STILL getting blocked heat exchangers on some of our jobs, approx. 2yrs after the boilers are installed.
Is there a fundemental problem with the Vaillant heat exchangers ?
Do other boiler manufactures have better designed heat exchangers ?
