Discuss Valiant combo boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
kiwikent
We had a gas plumber look at our boiler beacuse the pressure gauge was not working, just sitting on zero. He replaced it with a new one and its still a dud. He said that there was obviously other issues and I need to get a valiant specialist. The boiler actually works fine but I want to move a radiator and add a new one. So I need to drain the system but filling it again without a gauge? My question is can I fit an inline gauge anywhere on the system, I have a laundry room where I could fit it directly under the rad. I don't want to shell out another 180 quid on a boiler call out if I can help it. Thanks in advance
Yes you can fit a remote gauge anywhere on the system, I would put an isolation valve on first then a small gauge but have you tried pushing the minus button ( - ) on the boiler control panel ?
Are you saying you paid for a someone for a repair and a gauge that didn't work.
Are you also saying you accepted his diatribe about other issues and to get a Valiant expert.
How about questioning the bloke and asking him if he knows what he is doing and if he is sure about the correctness of the new gauge.
I would consider your problem a fairly simple problem and finding other issues , obvious.
I'll try the minus button thing when I get in from work, I've had the conversation with the plumber OZ, believe u me.....I didn't want to go into it here as it didn't seem appropriate and yes it was £180 inc VAT
Could be a very simple fix, as both gauges didn't work I suspect the "fault" was elsewhere (can't go into detail as against forum rules) but the engineer should have rectified it on his visit
You don't need a Vaillant specialist, just a better or more experienced engineer
+1 had this many times and very easy fix
Not sure age and model we've just moved in and inherited it. Posted pic if that helps
Reply to Valiant combo boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello All, I was hoping you could help with a potential boiler build query for my father. He has recently had a new boiler installed via British Gas (valiant brand). The external boiler flue seems excessively tall, proving to be somewhat of an eye sore (please see pictures attached). I know it...
Hi All, what's the cost of a service for an unvented system ? (valiant boiler & mega flow cylinder). I was charged £320.00, for the following: Boiler service - no parts changed. Change wireless thermostat (honeywell to Tado), I supplied the thermostat starter kit. is that about correct ? Also...
Dear professionals, could someone kindly advise on per below issue, please let me know if more pictures or details needed. I think my Auto Air Vent is now leaking. A little background on the boiler – installed a year ago in Feb, Valiant Heat only boiler Eco Tec plus 424, plus new pump. The leak...
Hi all I have a Vaillant eco boiler at a new house I moved into last week. It’s a combo boiler and the last boiler I had was old (and much easier to use!) This one keeps turning itself off. The hot water seems to work and is always warm. The heating also works but for random amounts of time...
Hi, I am replacing our 11 year old boiler (due to H.Ex. leak) with a new one. This is in a "sealed" system with red expansion vessel in airig cupboard & a megaflo (no tank in loft). However the exisiting boiler is Vaillant ecoTEC 4xx boiler - which is satated by vaillant as an "open vent" boiler...
