Discuss valiant EcoTEC radiator temp in the Central Heating Forum area at PlumbersForums.net
Thanks in advance. I have a valiant EcoTEC whilst the flow temp is set to 70 the heating flow only reaches a max of 45 when heating is demanded. (I can use chimney sweep mode to get to 70) but it means roads are never hot enough to warm house and boiler always on.
does this seem right?? Any ideas
Thanks all, controls are just a Honeywell wall stat and timer. What confuses me is that it does heat up on the “chimney sweep” mode.
Looking on line suggestions that the D0 setting being in auto is not very good? Don’t want to mess with any setting but any opinions on that? The boiler is serviced regularly but not sure they are seeing the same “problem” as I am!
Reply to valiant EcoTEC radiator temp in the Central Heating Forum area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
