Discuss Vent Pipe Blanked Off in the USA area at PlumbersForums.net
Would appreciate some advice I have a Potterton Suprima 60 Boiler system and a plumber doing a routine inspection of the system has stated in their opinion the system is not safe. This they have raised is due to no vent pipe being fitted to the F&E tank. Is anyone able to say if this information is correct, I should say the system has been working fine for well more than a decade without such a vent pipe. Any information and help is most welcome.
Has it been converted to a sealed system? Do you ever need to top up pressure?
It has never been converted, I will take some pictures when back at home. System has been working perfectly and has no issues. The plumber who was inspecting the system and installing a new cylinder due to the old one having a leak has written down the following comment on the paperwork:
'No vent pipe on heating system' to rectify the unsafe situation they have documented: 'Install vent pipe to F&E tank'
The house was built in the year 2000 and the heating system unchanged apart from the recent replacement of the leaking cylinder. There is no evidence that any vent pipe has ever been installed yet this plumber is convinced it needs one and that it is unsafe
Will measure the pipe, here are some pictures of the boiler used and the general view showing the pipework. If anything is not clear now at home in a position to take more pictures
Thanks for the input really appreciate it, the first picture that is blanked off the plumber today states there should be a vent pipe from this location and without this it is 'dangerous' in his opinion
Yeah I saw, possibly could have been reduced in the loft though. Although I very much doubt it.
It'll be a combined feed and vent with no vent - which is fine as far as I'm aware. For some reason new build builders started doing this about 20 year ago 🤷‍♂️
Thanks all for the guidance, here are some from the tank in the loft, for some reason the plumber today was describing the system as a potential 'doomsday' that needs a vent pipe ASAP
Would class it as needing updating slightly aslong as there’s no valves on the pipe leading to the air sep eg lowest pipe on the small tank then there’s nothing that bad
Yeah it's fine. If the system was to boil up (Which is why there is a vent pipe), it'll boil up back up the feed pipe. As long as there is no tap on the 'feed' pipe w
As I said, lot of new builds were done like this 20 years ago.
Thank you very much for the information, greatly appreciated, will continue as things are without having any additional unnecessary work done.
Assuming what the OP has is what is shown in figure 3 on page 10 :
then I fail to see the problem - it meets the boiler manufacturer's installation requirements and the boiler is designed to be installed this way. The OP's plumber may be used to older boilers that did not have the failsafe devices that allowed this kind of installation?
EDIT - just noticed the lack of vent on the cylinder, however. Is that supposed to be a vented or unvented cylinder - can others please comment?
Reply to Vent Pipe Blanked Off in the USA area at PlumbersForums.net
