Discuss Vent pipe on expansion tank. in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. Bogart
    Bogart Member
    Have inherited a half cocked system which am now trying to sort. Attached is a photo of the setup. well part of it. Am just being certain what the 2 pipes on the top of the air seperator are.Think I am correct in saying the 22mm pipe is the vent and the 15mm pipe is the feed/expansion one.
    Is it normal to have a seperator?
    Yes and I know the soldering looks dire even I can do better than that!
  2. ShaunCorbs
    15 mm is the feed from the f and e tank
    And yes 22mm is the safety vent
    There we'll know for getting blocked (air separator)
  3. Bogart
    Bogart Member
    The 15mm pipe from the F/E tank has a gate valve fitted is this a good idea or not as I suppose could be accidently closed.
  4. ShaunCorbs
    It's ok just label it if your worried
  5. townfanjon
    townfanjon Trusted Plumber GSR
    Yes it shouldnt be there , just take the wheel off , no dramas
  6. Bogart
    Bogart Member
    Exactly in fact just done that and labelled it.
    UTT
    • Like Like x 1
Loading...
Similar Threads - Vent pipe expansion Forum Date
Soil Pipe Vent Question Plumbing Forum Monday at 8:53 PM
Unvented cylinder D2 pipework Gas Safe Registered Plumbers Only Jul 11, 2018
