Viessman vs Vaillant and Honeywell vs Tado vs Hive
View the thread, titled "Viessman vs Vaillant and Honeywell vs Tado vs Hive" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I am trying to help my dad decide with a boiler replacement, can't decide between Vaillant Ecotec Pro 30kw or Viessmann Vitodens 100 30kw. The boiler will be going in the exact same spot as before.
Both will have a system cleanse, inhibitor and magnetic filter (I am not sure which brand or could be from the manufacturers)
The Vaillant has 10yr warranty and the Viessmann comes with 5 but you can pay an extra £120 to make it 10yr.
The Vaillant is slightly cheaper by about £150 (thats compared to the viessmann with a 5yr warranty)
So is the Viessmann a better boiler and worth the extra £270 ?
As to the controls can't decide between Honeywell, tado or Hive - they are pretty much all about £150.
Any advice on how to decide which way to go will be helpful.
From my very limited experience of boilers, I like the Vitodens. It has a nice internal layout that would seem to be easier to work on than many boilers. As I've never seen an Ecotec without a cover, I cannot compare the two, however.
Out of the 2 I’ve only worked on the EcoTEC pro, decent enough boiler, easy to work on and change parts - which I believe are cheaper than Viessmann. Opentherm or ebus (certainly on Vaillant) would help with modulation, thus saving on heating bills.
Reply to the thread, titled "Viessman vs Vaillant and Honeywell vs Tado vs Hive" which is posted in UK Plumbers Forums on Plumbers Forums.
Justice League,
Gasmk1,
