Discuss void meter cap off query in the Plumbing Jobs | The Job-board area at PlumbersForums.net
U
Unregistered
Hi, I work for a housing association as a inspector. I cant find this info in the Regs or HSE, when capping a meter on a void should the engineer put any form of label on the meter to advise its temporarily capped?
thanks C :)
As above.
Please register with us to receive an answer to your question.
Reply to void meter cap off query in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
