Discuss vokera 25he - can't work out heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Deleted member 99918
so i've just moved into a new flat.
Vokera Compact 25HE boiler.
hot water works fine, boiler kicks in as normal when tap is run.
however, i can't for the life of me work out how to get the heating working.
there is no roomstat in the property.
the rads all have their TRVs set to 3 (out of 5), but are stone cold. pipes feeding the rads are also cold.
i've had a look at the boiler panel and it appears to be OK, it's pretty basic.
can anyone gives me any p0inters?
Turn the dial switch from the sun to the snow flake
Then on the timer clock right side black switch push it down should come on then if it doesn't try moving the switch all the way up
But first if you have a room thermostat you need this all the way up eg calling for heat
i'll try that. i thought the snowflake was for the anti-freeze setting when it's not in use.
the black switch the right of the clock is currently in the middle which is apparently "auto".
there is no room stat anywhere in the property.
every rad has a TRV apart from the one in the hall which doesn't.
ok an update.
i turned the dial to the snowflake and it kicked into life.
all rads started to heat up, and the pressure gauge raised from 1.5 to about 2.5-2.7.
so i now have heating and hot water.
however, with a roomstat i'm guessing i'll have no way of controlling the room temperatures without having to adjust the boiler each time?
the black switch on the timer dial is set to auto.
i did notive the green LED was flashing constantly whilst it was heating up the rads.
i've found that the supplied manual doesn't really match what is physically on the boiler. it says the timer dial should be lined up against the white pointer, but mine doesn't have a pointer.
also, the section about the middle dial doesn't match what the boiler has either.
a final question about the TRVs and the rads.
the TRV goes from 1 to 5, and an OFF, but there is also a snowflake option too? (see pic).
there is also another nob on the other side of the rad (with a + and -), what does that do? (see pic).
on the boiler the snow flake is winter mode eg heating and hot water, sun is just hot water eg summer mode
correct other than time you dont have any room temp setting
snow flake on the trv is a frost setting eg background heat
normally bedrooms around 2-3
halls 3
living rooms 3-4 ish
find whats right for you
thats a lockshield have leave this one alone
i'm not sure if the lockshield has been turned/moved or not.
is there a way to know what it should be set to?
it's a 1 bedroom flat.
rad in living room.
rad in kitchen (which actually is joined to living room)
rad in hall (where front door is) - this doesn't have a TRV
rad in bedroom
rad in bathroom
the kitchen one i'll probably never use - so i guess either set that off or snowflake?
bathroom again, might never really be used, maybe set to 1 at best.
when you said "other than time you dont have any room temp setting" do you mean when the timer clock on the boiler is set to off?
if i was to get a wireless roomstat, would this give me better control?
one thing to note, the boiler is in the bedroom, and it's quite noisy. not ideal if you're trying to sleep and the boiler kicks in.
i would leave it if they heat up
set the kitchen to 1 and see how you go and its down to what you find that works for you
i mean it will run until you turn the clock off / until its set to eg 9am -11am
yes it would give you control over the air temp eg set it to 20 dc turns off when its in that range
thats down to your boiler there are some noisy and some quite
Reply to vokera 25he - can't work out heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
