Discuss Vokera compact 29a pressure almost 0 in the DIY Plumbing Forum area at PlumbersForums.net
Hey, I noticed today that the pressure has dropped to almost 0 in my vokera compact 29a boiler.
There is a flexi pipe just below with 2 black taps and usually turning those will increase the pressure but it’s not working this time. I have a picture attached.
The tap on the left let’s water out when turned and nothing happens when I turn the one on the right.
Anyone any ideas?
Take the plastic valve handle off and turn with a spanner. Sometimes they wear the plastic so dont turn on when you think it's on.
Reply to Vokera compact 29a pressure almost 0 in the DIY Plumbing Forum area at PlumbersForums.net
