Discuss W plan wiring using midposition valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi is it possible to wire up to work has a W plan using a mid position valve? If so any advise? Thanks
Found this online bud . cheers kop
If you connect the white and grey wires together they become the equivalent of the brown wire in a diverter valve. The orange is not used, so it should be "parked" in an unused terminal of the wiring centre.
Why are you thinking of W Plan?
Reply to W plan wiring using midposition valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down through slab and out through deadwork into a manhole. I will work out falls from manhole and set the height of the waste water system as required. For...
