Discuss Want to add immersion heater to Worcester Heatslave 20/25 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Worcester Heatslave 20/25 in reasonable shape, and am about to install a load of solar PV on the roof. There will be excess capacity from the solar that I want to divert to an immersion heater to reduce the load on the oil boiler.
I was wondering if I could fit an immersion heater coil into the water tank which is built in to the boiler? That will be much cheaper than a separate unvented HW cylinder (which I'm not sure will work with the boiler anyway?)
No you can't and an unvented cylinder could be added so the solar just heats the water and as a back up it could be connected to the heating circuits incase there's not much sun
The whole point of solar is to use renewable energy, or to be more self-sufficient.
The whole point of PV is create electricity, a high-grade energy that it is wasteful to use to heat water. At least use it to charge an electric vehicle rather than just to heat water, please!
If you want to heat water, how about solar thermal? You might still be able to get the renewable heat incentive RHI and then you'll need a much smaller collector area for the same output. Solar thermal will give you more heat per square meter than PV running an immersion heater.
Of course, if it's about money there are various ways to invest money.
If it's about being eco, but you want to make some money, have you considered buying shares in a community wind farm project? It may give a better return than solar!
Thanks both. The main intention of the PV is self sufficiency for a barn conversion near the house, and we'll be planning for maximum use of electricity when the most is produced during the day (and using an air source heat pump for under floor heating).
Often the barn will not be able to consume all the power that's being produced, and exporting to grid for RHI these days is hardly worth it (the extra cost for MCS accreditation doesn't get covered by feed-in amount). So I'm looking for ways to use the power elsewhere on the site before exporting back into the grid.
If/when we get an electric car yep we'll use it to charge it, but that won't be happening for a while yet! If battery storage gets cheaper, I'll consider using excess PV to charge batteries for house use - but for now the best route seems to be to use less oil by heating water.
Solar thermal is an extra option that may or may not be added, but the main thing here is to make use of excess PV electricity.
Renewable Heat Incentive is for producing heat which obviously there is no way of feeding into a grid. For electricity I assume you mean the Feed-in Tariff and Generation Tariff.
Yes, running a heat pump is a good way of using the electricity, and underfloor is a very good use of the heat as it allows the flow to be at a lower temperature, improving the COP. You might find the following link to be of interest:
Heat Pumps | CAT Information Service
I'd look into this further (unless you have already). As a friend of mine with a very keen interest in renewables and a reasonable level of theoretical technical background seemed to think (even as of earlier this year) it would be worth his while paying for a 3.6kW solar PV array, based on the electricity saved PLUS the FiT and the generation tariff. He showed me the feasibility study and it seemed accurate to be honest.
Heatslave is a combi. Unvented will work but you need somebody who knows what they are doing and qualified to do it.
Use combi to run 1 tap then addition of external controls and pipework to feed uv. Won't be cheap.
OK, sounds like I might be better off planning the barn HW tank for the heat pump to take an immersion heater instead, and leave the house (heatslave) for another time. Then the ASHP could probably stay off most of the summer. Good tips, thanks.
(yes Ric I did mean FIT not RHI! Too many acronyms...)
Reply to Want to add immersion heater to Worcester Heatslave 20/25 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, We are having PV panels fitted which will dump the excess energy into our hot water tank. Our house originally had a large 210L economy7 hot...
I have just had a new boiler and 210 ltr unvented tank fitted in the loft to replace a very old Baxi back boiler. I have now fitted a Solic 200...
Hi everyone I have a 20 year old Megaflo CL250 indirect hot water tank that I typically heat with an oil-fired boiler. It has locations for two...
2K
Hi, I would really appreciate some advice on a proposed change to my central heating circuit. I am able to divert excess electricity from my...
2K
Hello all, I should start off by stating that I'm not in the industry - I'm just a DIYer with a "what-if" idea. Hybrid systems and solar...
