Discuss Was my smart thermostat installed incorrectly? Or what is the issue? in the Central Heating Forum area at PlumbersForums.net
When I set it to be on via phone, light A comes on (telling it to be on), but light B won’t come on, so the boiler doesn’t start. I either need to set A on and off several times via phone, or turn it off and on again via switch (C).
When I set the water to be on, it works instead, and green light B does come on.
What can it be? If the wiring had been done badly, it just wouldn’t work right? Then what it is?
  • Worcester Bosh Greenstar Ri boiler
  • Drayton wiser system
Could be wiring or a port valve switching on and off a few times leads me to port valve
Could you clarify this bit?
As additional info, I used to have a different thermostat - Honeywell - with a timer, and I never experienced these issues.
Turn the heating on via the app and wait an hour might be a delay / in x the heating will come on etc
But with the old thermostat (not smart, no app, just wall panel) it used to turn on automatically…
There might be a delay / its manufactured to do this
Reply to Was my smart thermostat installed incorrectly? Or what is the issue? in the Central Heating Forum area at PlumbersForums.net
