Discuss Washing machine installed correctly? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi there,
We have noticed a funny smell coming from behind our washing machine - on investigation it looks like the waste pipe is leaking where it meets a solid plastic U - now what I want to know is if this is installed correctly? The waste pipe runs downwards from the top of the washing machine and then up into one side of the plastic U, pushed in (the end of the waste pipe is rubberised and the plastic bend is hard plastic) which is oriented as an n, the other side of which disappears behind some panelling. Where the pipe meets the bend and below there is a dark coloured sticky smelly residue. Could someone show me how a correctly installed washing machine waste pipe should look like?
Many thanks.
Your trap might be leaking, if that's the case it wont prevent odours coming from your waste stack.
Reply to Washing machine installed correctly? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
