Discuss Washing machine pumped waste in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello
Installing washing machine in remote location under stairs/ no drain near by
here’s what I’m proposing but never done before so thought I’d have an ask,
Fit washing machine with hose into hockey stick trap then connect to Grundfos sololift C-3 lifting station, core through the wall to outside and come up 2-3metres vertically then run 8 metres to the external stack.
Would connect to pump with 1” 1/2 and exit the pump with 1” 1/2
Ever done anything like this before?
Is it fine externally (would it freeze)
Any advice / comments / help are appreciated Thankyou
Remember that they only like one vertical and dont like sharp elbows when planning the pipe route. Some say direct connections to the pump so no need for the hockey stick being required. 40mm outlet pipe is unlikely to freeze because the water will be gone but you could lag it anyway and put the Grundfos in a wooden box stuffed with insulation leaving the vent clear and you should be alright.
Reply to Washing machine pumped waste in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
J
Hello Installing washing machine in remote location under stairs/ no drain near by here’s what I’m proposing but never done before so thought...
James I
J
Hi, I have just moved the washing machine into the garage and it will not drain. I wonder if it's something to do with the way I have installed...
A few months ago I wanted to connect a 1000l water butt (fabricated from galv steel) to our washing machine. After trawling many forums and...
Hi, Installing 2 new bathrooms, property only had 1 bathroom and the waste went into a cast iron soil stack which has now been replaced. I...
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution...
