Discuss Waste water pump in the USA area at PlumbersForums.net
Matt0029
Hi can anyone recommend a good waste water pump. For clean water so won't need a macerator bit. It's for a waste run that now has 6 meters pipe with a fall of 20mm. So well out of limits for the required fall. Has been tested yet but I don't think will work without a pump.
What size is the pipe and does it rise after the pump before the 6m run with the 20mm fall on it?
It would need a trap on the straight run of waste pipe. Wondered whether they would be enough pressure to force from a hepvo trap horizontally with the lack of fall.
With hepVo traps you loss about 10/20 between inlet and outlet.
There's the mcalpine one that is straight so wouldn't loss any fall on the trap like the hepvo. But sure I read somewhere these aren't to be used on showers. So may not have the force in the water to open it? Thanks
Reply to Waste water pump in the USA area at PlumbersForums.net
