Discuss Water Circulator Pump Bust After Only 1 Year! in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all, we have a water circulation pump to bring hot water from our woodburning stove and send it to a thermal accumulator tank. We've just started our second season and it's broken. I thought these were meant to last 10 - 15 years?
We don't have a domestic water supply - we use water from our own well which is filtered through a separate pump and stored in a storage tank for domestic water use. Is it possible that the "untreated" water could be the cause of the problem? At 300 quid per pump, I don't expect it to break each year!
Perhaps I should have drained the system over the summer so that water wasn't sat in the pump - could this be the root cause?
Photo of the pump in situ, and the part that broke, are below.
Many thanks
Also £300 per pump not a chance
Pumps arnt rated really for solid fuel temps
Would recommend a steel impella
As Simon has hinted, this should be done by gravity really. Get someone in to look at your set up, someone who knows what they’re doing.
Reply to Water Circulator Pump Bust After Only 1 Year! in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
Sonya K
