Discuss Water cylinder pump problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gudu
Hello,
The pump from my hot water cylinder has started making the noise it makes when running on and off continually, even when no taps are running.
I left it for hours but it's still doing it. Turning it off and on again at the wall also hasn't helped.
I've uploaded a video showing the problem:
Does anyone have any ideas what the problem may be , please?
I'm not sure what you mean, I'm afraid.
The pump still works fine when taps are used but when no taps are on then it makes the constant on/off noise on the video.
Is there anything running in the vid (only ask as I can hear water running ??)
The dripping is the cold water storage tank filling up. I'll have another look for any leaks any where.
Unless you have just run some water shouldn't be dripping
Could be a leak somewhere
Got any dripping taps ? something like a small drip can be enough to kick in the flow sensor, or sensor is faulty, worse case new pump, is it only supplying hot water ?
Reply to Water cylinder pump problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
