Discuss Water filled towel rail overheating in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have a water filled towel rail which has been working for several years.
It is now getting very hot and making a noise.
Do these loose water over time and need topping up?
Could this be the problem or a faulty thermostats or element?
Any way to diagnose the problem?
I have a similar towel rail, not with that fault, but it has lost a bit of water, and that part of the rad at the top with no water is much colder than lower down where the water is present. Also my rad does not make a kettling noise.
I suspect the integral thermostat in your heating element. Normally a straightforward job to change the whole element/thermostat with the rad turned upside-down!
PS is there a separate temperature control that is not part of the element assembly? A photo of that part of the heating element you can see would be helpful.
I have removed the thermostat.
It's a three pin plug in type.
Looked on line and can't see a replacement.
Any idea where I can get one?
I have never seen one of those!
But here is one! NAUTI-TH-1 towel rail thermostat | eBay - https://www.ebay.co.uk/itm/155292541626
Probably worth getting to try.
But I wonder if the faulty bit might still be in the immersion element still in the radiator?
If the above doesn't fix it, I suggest buying a replacement complete element assembly of your choice, and abandoning all of the original.
E.g. simple element with fixed temperature:
Or element with adjustable temperature:
Appreciate your reply.
I did search eBay but missed that.
Have now purchased that item.
I did measure the element resistance and it checks out.
Will try the thermostat and if not will buy a complete new unit.
Reply to Water filled towel rail overheating in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
