Discuss Water Hammer following Combi boiler installation in the USA area at PlumbersForums.net
Worcester Bosch Greenstar i combi installed. Since installation water hammer happens when hot taps are turned off, but only when the heating is on. Have you experienced the sam?
Do you have a shock arrestor fitted ?
It might be not set correctly as it’s just an expansion vessel
Reply to Water Hammer following Combi boiler installation in the USA area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
