Discuss Water in tundish in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an unvented hot water system and water started leaking from the expansion vessel. I called a plumber and he came and replaced the the vessel but since then if i feel around inside the tundish it is wet, not dripping, just a bit wet inside towards the top and sometimes a little water falls when i touch it. Is this normal?
Also since, a couple of taps seem to be surging slightly and slightly under pressure.
Any help will be greatly appreciated
The tundish (in normal operation) should be completely dry. If it is wet one of the relief valves is either lifting or passing.
It looks as if your plumber did not properly check over the system after replacing the expansion vessel. Or possibly used the T and P valve to depressurise the system and has not properly reseated it.
As referred to above the plumber needs to be G3 qualified
As Brambles rightfully says one one or both of the Temperature and Pressure (T&P) and Expansion Relief valves are not seated properly and passing a little water. Either because the expansion vessel is not properly charged with air or they are failing to seat after testing during the last repair.
The surging is caused by a different issue, poor flow of water through the Group Inlet (AKA "Combination Valve") usually because the strainer is becoming blocked. It can also be caused by the pressure reducing cartridge in the Group Inlet failing but in my experience that is unlikely.
Sorry to say this is not a DIY job and needs a competent G3 plumber to rectify as in the UK you must be qualified/registered to work on these cylinders. Other country's rules may differ on that though.
I think it's only been serviced once since it was installed 4-5 years ago. Several plumbers, including the one the changed the vessel, said it doesn't really need servicing. How do i find a decent plumber in my area that has g3?
CT15
They're supposed to be serviced every 12 months.
As for finding a decent plumber it's best to ask friends, neighbours, colleagues etc for a recommendation.
Or somebody on here may be close.
CT15
Any plumber who says they don't need servicing is simply wrong I'm afraid. Every manufacturer of the cylinders I have fitted over the last 14 years states they need to be serviced annually and when you understand how one works it becomes obvious why they need servicing. Both for safety and performance reasons, not to mention keeping up the guarantee on the cylinder.
You could try posting here to find a plumber from the forums Looking for a Plumber? Post Jobs Here
The problems you are experiencing are not "major issues", although I suppose that is subjective but you can get this easily sorted with the right plumber working on it.
Reply to Water in tundish in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
