Discuss water megaflow combination valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
rifraf37
Hello, I had a leak from my combination valve and had a plumber replace it with a relience one a (3 bar / 8 bar unit). However now the temperature of the cold water is high(hot) unless i run off a lot of water. How do i get the cold water back to being cold again? do i need to call the plumber back out?
many thanks.
yes you need to call your plumber out again and please make sure he is qualified to work on unvented cylinders by way of the G3 qualification.
Definitely get the plumber back out, sounds like the cold water is connected to the wrong place.
Reply to water megaflow combination valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I’m having issues with cold water to multiple outlets. Taps, showers, toilets cold water is fine at the kitchen sink. The hot water system is a Glenhill unvented cylinder. Hot water is fine at all outlets. I assumed the cold outlets not working were from the balanced cold from the...
2K
Hello. My home's Rheem water heater is dripping from the drain valve. It is strange as it seems to sometimes spit out some water and then stop and then occurs again. I have a little plastic bucket to collect the water, probably about 3 cups of water in a 24 hour period. I was doing some...
We have had an ongoing issue with low hot water temperatures in a school. During the recent repair of a leak, the plumbers isolated the hot water to fit a new bit of pipework and found that water wouldn't stop running until the cold boosted water was also isolated. Given this, it would seem...
Good evening, I'd like your opinion on something that is worrying me please: my landlady's plumber replaced the bottom/night element of my 20-year-old unvented cylinder (an Ariston Classico HE STD 150) 5 days ago and I hadn't noticed that it was leaking. He fixed the leak today but now the...
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that heats on controlled load over night. The large tank is in roof space of 60s built villa unit. Every few mornings, no hot water will come out of...
