Discuss Water pump pressure Issues.. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Greetings, newbie here, kindly seeking advice on a water pump issue I have. Before I get started, I'd like to mention that I'm a complete novice and have no prior experience with pumps or plumbing.
Basically, I'm in the process of purchasing a home that is out in the sticks and has a 120ft well as its water source. The 'well' pump is fine, the problem is the second pump that pulls the water out of the tank which feeds the house is struggling to supply sufficient pressure (I have added an attachment with the spec. Marquis Pump).
I have found a local supplier that has a Grundfos pump that could perhaps be up for the job. The spec on this one (see attachment) seems promising. My question is, is it too powerful? and if so could this cause other problems?
Thanks in advance.
What tank do you have ?
Hi, thanks for your reply. I should know the answer to this but unfortunately, I don't. I will find out tomorrow how many liters or gallons it holds. If I'm not mistaken, I seem to remember the previous owner telling me it's a 500-gallon tank. But I could be wrong.
Is there a pressure vessel aswell ?
Reply to Water pump pressure Issues.. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I am currently using a Grundfos Booster Pump. This pump is fed by 2pcs of 1,000 liters water tank. Normally the pump would stop working...
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
Hi there, I’m hoping someone can help me with this problem please. I’ve searched for similar posts but not found anything helpful! My mum’s...
Pumps and low pressure I moved the bathroom to the back the house (next room) upstairs. I put in two pumps because low pressure water area. One...
