Discuss Water shut off cylinder in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
W
Wojciech
Is it possible to replace inside part of the water shut off cylinder without replacing whole cylinder?
Reply to Water shut off cylinder in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
