Discuss water softeners in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sil-Phos balls, change the water without softening it, the water is permanently hard, and so does not precipitate the lime on heating, just a word of caution the quacks recommend the there is at least on cold water tap coming directly of the cold water main, apparently soft water can be bad for the heart
i used to live in hants and boy was the water hard there, used a magnetic water treatment divice in all my houses in this area and never had any scale problems with heat exchangers or kettles scaling up. Didnt need to put any chemicals in my water or top up sofeners ever. cant understand why every one doesnt use magnetic/electric treatment. Works on the same principle of ionisation of the carbonates preventing them causing scale build up.
Well, i used to live in hants and boy was the water hard there, used a magnetic water treatment divice in all my houses in this area and never had any scale problems with heat exchangers or kettles scaling up.
Post from 4 years ago [emoji15] probably sorted by now!
I wonder what he ended up with?
Reply to water softeners in the Plumbing Jobs | The Job-board area at PlumbersForums.net
